mielcu3
Mar 21, 2023Tutor
Ready NAS RN316 - Xpenology installed with success
Hello team, I just wanted to brag my self. I installed with success Xpenology DSM 7.1.1 on my ReadyNAS RN316 unit. It works flawesslly. II also backed up internal drive, where RN storage his own boo...
mielcu3
Mar 28, 2023Tutor
I believe there is a way to connect external vga card. Most of readynas units has on board unused pci-e slot which can be used for graphics. One thing is necessary: pcie riser cable. It is needed because you have to at least once go inside bios and change boot order and disable onboard flash drive/memory and exclude it from boot order. With riser cable you can connect external graphic card outside readynas box.
Sandshark
Mar 28, 2023Sensei
Unfortunately, no, most ReadyNAS do not have a PCIe slot. And ARM based units use UBOOT, which is another obstacle.
- mielcu3Mar 30, 2023Tutor
Yesm you are right. I had on my mind readynas units based on Intel CPUs. Those units have mostly free pcie slot on board. Even so, there i believe there is no xpenology for arm readynas.
