pipis89
Oct 26, 2016Aspirant
Ready Nas update Fail and storage
Hello everyone..!!! I already have my Nas 3 year nows..I am using it on my job as surveyor enginier and i today i had a problemme...!!! After a reboot it says to me a message that it couldnt mount f...
- Oct 26, 2016
O.K. You had 6.1.4 on this unit and tried to use 6.1.5 to fix it using USB Boot Recovery.
I had a look at the system remotely and manually updated it to 6.5.2 and it came up fine. Also then updated it from 6.5.2 to 6.6.0 without any problems.
Oct 26, 2016Guru - Experienced User
The flash memory issue points towards a hardware failure in the chassis.
The warranty on the RN104 is three years, so check the purchase date - you might still be covered by the warranty.
Support might have some other way of reloading the flash, so you might want to contact them. There is a USB recovery procedure, but I'd wait for a Netgear response before trying it.
As far as your data goes - if the disks are ok (no reason to think they aren't) the disks can be placed in another OS 6 NAS, and the data should be intact.
