pipis89
Oct 26, 2016Aspirant
Ready Nas update Fail and storage
Hello everyone..!!! I already have my Nas 3 year nows..I am using it on my job as surveyor enginier and i today i had a problemme...!!! After a reboot it says to me a message that it couldnt mount f...
- Oct 26, 2016
O.K. You had 6.1.4 on this unit and tried to use 6.1.5 to fix it using USB Boot Recovery.
I had a look at the system remotely and manually updated it to 6.5.2 and it came up fine. Also then updated it from 6.5.2 to 6.6.0 without any problems.
pipis89
Yea after the Usb recovery it shutt down..but when i turn it on after it tells me the same message..!!!
how i can use my data now from the HD if i cant take a new one soon??
is there any chance to reset it back to factory settings and work??in that case what will happend with my data??it will recognise the raid 1.0 from the HDD or it will format them to make a new one???
if i conect the HDDs to a pc could i take a bck up from my data or the raid puts them that way tha i will not be able to read them..??
thank you for your fast response
mdgm-ntgr
Oct 26, 2016NETGEAR Employee Retired
I've sent you a PM.
A factory reset won't fix this. A factory reset wipes all data, settings, everything. It doesn't fix a problem with the flash.
