jonrico's avatar
jonrico
Ready NAS104 - Bit rot protection - silent error
I purchased and setup a ReadyNAS 104 10 days ago and set it up with 4x4TB WD Red drives. Its running firmware 6.2.2.
I then copied around 3.5TB of data (mainly media files) from old USB drives to the NAS and everything has been fine until yesterday when I got a slew of warnings (around 80 email alerts) all saying
warning:volume:LOGMSG_BITROT_WARN Bit rot protection has detected a silent error within /path/to/some/media/file on /dev/sda3 and cannot correct the error.
The errors were in two files. I have since replaced these files with equivalents from a different source and run a disk test which reported no errors although I am not sure where to look for results - there were no more warnings and nothing added to the web visible logs other than disk test started, disk test completed. The test took 11 hours approx.
I have downloaded a set of logs after the disk test but am not sure what to look for. The volume.log file says (for all four drives)
Reallocated Sectors: 0
Reallocation Events: 0
Spin Retry Count: 0
Current Pending Sector Count: 0
Uncorrectable Sector Count: 0
but the smart_history.log file has not been updated past the initial first time startup logs on Feb 20th.
Should I be concerned about this? Thanks for any advice.
ProSupport for Business
