octoday
Jul 28, 2020Tutor
readycloud desktop
Two Macbook Pros running Mojave 10.14.6. Same antivirus program in background, same firewall settings, same permissions. Sitting side by side on same network, one connects to server via ReadyCloud se...
- Aug 03, 2020
Because ReadyCloud did not appear in the preferences folder — in Mojave, at least — and I could not isolate the problem, I went into the library and deleted every trace of ReadyCloud and reinstalled a fresh copy. Whatever setting differed from that on my other Mojave Macbook Pro and Mac Pro was rectified and the app resumed normal functionality.
octoday
Jul 28, 2020Tutor
I'll give it a shot. Can I do that remotely or do I need to be on the LAN?
Marc_V
Jul 28, 2020NETGEAR Employee Retired
If you need to do it remotely you should be atleast connected to a VPN since if you are connecting from ReadyCloud,you will lose access once you turn it off.
BTW, have you tried logging in to ReadyCloud portal on the Mac that is having the issue?
- octodayJul 28, 2020Tutor
I have no problem logging into the portal on my problem mac. I'm working off that instead of the VPN. I'm just trying to avoid going into the office and dealing with the problem with RAIDar. I'm just obsessing over why two identical Macs act differently. Thanks.
- octodayAug 03, 2020Tutor
