AndyAnon
May 01, 2016Aspirant
ReadyDATA 516 bootup issues
I have the above titled unit (x2) both with issues .. unit 1 power on ok however even when connected to a network and showing ethernet connection activity fails to load have tried ; Memory test...
- May 02, 2016
I have moved your other post from ReadyNAS in Business to the appropriate section: https://community.netgear.com/t5/ReadyDATA/rdd-516/m-p/1080717#M304
Please, in future when we tell you to post in the appropriate section listen to that advice. ReadyDATA posts do not belong in the ReadyNAS section.I am now locking this thread. Discussion can continue in the other one.
May 01, 2016Guru - Experienced User
These are ReadyDATA units? If so you posted in the wrong forum area - this is for ReadyNAS.
AndyAnon
May 02, 2016Aspirant
aploogies fo that - its due to the over complicated community system at netgear with auto reloads and labels etc.. seriously what is wrong with a simple basic forum layout that has worked for over 20 years....
will try mave it the correct location...
netgear? your system is over complicated...
- mdgm-ntgrMay 02, 2016NETGEAR Employee Retired
