rossini
Jul 29, 2011Aspirant
ReadyDLNA 1.0.21 for Samsun LED TV Type C
I just installed version 1.0.21 of ReadyDLNA for my ReadyNAS 1100. As I am a new owner of a Samsung Series C8790 LED TV (newest firmware), I had hoped that it would help me with my FF/REW "not avai...
octy
Aug 06, 2011Aspirant
Edit: Ooops, sorry I didn't see you use a 1100, not a Duo.
I let the message...
Hi,
Apparently, the patch to support C series is not applied into the readyDLNA mainline.
I'm not sure of the reason, but I've read that this patch allows to support C series while it breaks support of a lot off other versions (this information is available into the patch comments).
So I think without solving this version incompatibility the C series patch will not be integrated.
I don't know if someone is working on this issue.
Nevertheless, there is a specific build for C series.
You can find manual installation process (at your own risk :? ) here: http://www.readynas.com/forum/viewtopic.php?f=76&t=51478
Best regards,
octy
Hi,
Best regards,
octy
