rattee
Jun 08, 2012Aspirant
ReadyDLNA not displaying all folders on TV
ReadyNAS NV+ running firmware 4.1.8 I have ReadyDLNA enabled with my Share "media" selected with no folder specified and "All" Content Types selected. Not all folders are displaying on my Samsun...
Jan 24, 2014Guru - Experienced User
If you want to run commands, then you need to enable ssh by installing the add on here: http://www.readynas.com/?p=4203
Choose "sparc" for 4.1.x firmware, "arm" for 5.x firmware.
You can also look download logs from the WEBUI, and then examine them on the PC - probably the best way to get started. There is a dlna debug add-on you can run that increases the logging. You install it again to turn it off. You can find that here: viewtopic.php?f=76&t=27946
