Jul 07, 2012Guru - Experienced User
ReadyDLNA OS Partition Usage
I just noticed that ReadyDLNA's database and artwork cache are stored on the OS partition (/var/cache/minidlna). On my system that is about 600 MB of the limited OS partition space :shock:
Is there any way to shift that stuff to the C Volume???
- mdgm-ntgrNETGEAR Employee RetiredI can confirm I get this issue in 5.3.5 when I change the settings for ReadyDLNA on a share, either enabling/disabling ReadyLNA on the share or changing the media type for the share. I'm just trying a reboot now.
- SkywalkerNETGEAR ExpertFYI, the db_dir setting should stick for you once 5.3.6 is released.
- jhobsonAspirantEra on 5.3.6 though ?
- SkywalkerNETGEAR ExpertFrom what I understand, it should be available within the next few weeks.
- jhobsonAspirantFYI no... 5.3.6 did NOT fix this problem, it still overwrites db_dir setting back to the default of: db_dir=/var/cache/minidlna
- SkywalkerNETGEAR ExpertYou may need to run something like:
sqlite3 /var/readynasd/db.sq3 "update service_dlna set db_dir = '/c/.readydlna'"
- EtzAspirantBasically we need to fix it, because my X86 root is filling up...
I made some config file changes and freed, myself from this problem, but what should 99,8% x86 unit users do, who dont have SSH acces, or ven dont know what it is? - mdgm-ntgrNETGEAR Employee RetiredHere are the add-ons to Toggle the ReadyDLNA CacheDir for x86 and SPARC:
Skywalker wrote:
x86: http://www.readynas.com/download/addons/x86/4.2/Toggle_ReadyDLNA_CacheDir_1.0-x86.bin
SPARC: http://www.readynas.com/download/addons/4.1/Toggle_ReadyDLNA_CacheDir_1.0.bin
For ARM currently you would still need to do it manually. If you need help manually updating the sqlite3 database entering the command Skywalker suggested I could assist with that.
