njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location ...
tim_hamblin
Dec 31, 2011Aspirant
Seems to be similar issues with the new ReadyNAS Duo v2 (running arm v5.3.2)...
DLNA appears to be a bit flakey - if you update/add any files its doesn't update the DLNA side of things (i.e you correct a ID3 tag - the original is still streamed, or if you even rename a subfolder and/or a file - again the orignal version is still streamed). There appears to be no 'Rescan' option (as found on the older version 1 ReadyNAS boxes)... Even a reboot doesn't seem to fix things - only fix is a Factory Reset and ensure you only upload 'perfect' files for DLNA streaming...
Also have problems with ReadyNAS Remote to iOS devices (iPhone/iPads) - keeps asking you to check/enable FTP Service on your iPhone/iPad for access - but there appears to be no way of doing this on the new ReadyNAS v2 boxes...???
