njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location ...
mdgm-ntgr
Jan 19, 2012NETGEAR Employee Retired
Are you willing to try 5.3.3 beta?: http://www.readynas.com/forum/viewtopic.php?f=148&t=60215
If you update to that and then download the logs zip file (open the dashboard, click Configure, go to Health > Logs and click download logs) and extract the zip contents what does upnp-av.log look like?
