njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location ...
ramiromagalhaes
Jan 20, 2012Aspirant
So, here is my upnp-av.log As you can see, it scans a /c/Media folder, but there is no folder such as this one in my drive. In fact, I renamed it to c/public folder (it shows in my FrontView without the "/" before the "c/public"). Inside such folder, there are still c/public/Music, c/public/Pictures or my c/public/Videos. I must say that I did set c/public to be shared via ReadyDLNA service, and I assume it scans my subfolders.
If there is any other information I can provide to help solve this problem, please, let me know.
[2012/01/18 18:16:19] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:16:19] minidlna.c:920: warn: Creating new database...
[2012/01/18 18:16:19] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:16:19] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:16:19] scanner.c:719: warn: Scanning /c/media
[2012/01/18 18:16:19] scanner.c:790: warn: Scanning /c/media finished (0 files)!
[2012/01/18 17:41:35] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 17:41:36] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 17:41:36] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 17:41:36] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 17:41:40] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 17:41:40] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 17:41:41] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 17:41:41] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:01:55] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:01:55] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:01:55] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:01:55] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:01:58] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:01:58] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:01:58] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:01:58] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:02:23] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:02:24] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:02:24] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:02:24] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:02:33] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:02:34] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:02:34] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:02:34] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/18 18:02:54] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/18 18:02:54] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/18 18:02:54] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/18 18:02:54] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 11:48:43] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:22:42] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:22:42] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:22:42] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:25:54] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:25:54] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:25:54] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:25:54] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:26:01] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:26:02] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:26:02] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:26:02] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:26:02] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:26:02] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:26:02] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:27:26] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:27:27] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:27:27] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:27:27] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:27:27] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:27:27] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:27:27] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:30:15] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:30:15] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:30:15] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:30:15] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:30:15] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:30:15] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:30:15] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:30:26] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:30:27] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:30:27] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:30:27] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:30:27] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:30:27] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:30:27] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:30:31] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:30:32] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:30:32] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:30:32] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:30:32] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:30:32] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:30:32] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:30:50] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:30:51] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:30:51] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:30:51] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:30:51] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:30:51] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:30:51] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:38:01] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:38:01] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:38:01] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:38:01] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:38:01] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:38:01] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:38:01] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/19 14:38:14] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/19 14:38:15] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/19 14:38:15] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/19 14:38:15] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/19 14:38:15] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/19 14:38:15] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/19 14:38:15] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/20 12:05:12] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/20 12:11:45] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/20 12:11:45] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/20 12:11:45] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/20 12:11:45] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/20 12:11:45] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/20 12:11:45] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/20 16:17:12] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/20 16:17:12] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/20 16:17:12] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/20 16:17:12] inotify.c:89: error: inotify_add_watch(/c/media/Pictures) [No such file or directory]
[2012/01/20 16:17:12] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/20 16:17:12] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/20 16:17:12] minidlna.c:997: warn: TiVo support is enabled.
