njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location ...
mdgm-ntgr
Jan 20, 2012NETGEAR Employee Retired
Have you tried turning ReadyDLNA off then on again? Is there a reason you needed to remain the /c/media folder? If you do you could try renaming it back, then disabling ReadyDLNA, then renaming it to public again and then re-enabling ReadyDLNA and see if that works.
