njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location ...
ramiromagalhaes
Jan 23, 2012Aspirant
I renamed my /c/media folder to /c/public because people here are used to using a "public" directory to share things.
I did a factory reset with the 5.3.3 BETA firmware, cleaning up my disks. Then, I created some users (I did not attach to no shares, but I thought that I should mention that). Then I copied some music into the /c/media folder and waited some time. I went to check on my LG TV and the song list updated ok. After that, I added pictures and a movie, and everything did show on my LG TV. Afterwards, I renamed the folder to /c/public and, although the files were listed, I could NOT view or listen to my media. So I stopped the ReadyDLNA service and restarted it. Again, all media was listed, but I couldn't view or listen to anything. At last, I tried to reboot my ReadyNAS, and I had the same problem again.
I made all that via the FrontView interface. Here is my upnp-av.log. It seems to me it shows the database was not updated.
[2012/01/22 16:01:12] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/22 16:01:12] minidlna.c:920: warn: Creating new database...
[2012/01/22 16:01:12] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/22 16:01:12] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/22 16:01:12] scanner.c:719: warn: Scanning /c/media
[2012/01/22 16:01:12] scanner.c:790: warn: Scanning /c/media finished (0 files)!
[2012/01/22 23:07:45] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/22 23:07:46] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/22 23:07:46] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/22 23:07:46] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/22 23:07:49] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/22 23:07:50] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/22 23:07:50] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/22 23:07:50] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/22 23:25:30] upnphttp.c:951: error: recv (state0): Connection reset by peer
[2012/01/22 19:52:20] upnphttp.c:951: error: recv (state0): Connection reset by peer
[2012/01/23 00:36:06] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 17:25:34] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 17:25:34] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 17:25:34] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:16:57] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:16:58] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:16:58] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:16:58] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:17:03] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:17:03] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:17:03] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:17:03] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:17:46] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:17:47] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:17:47] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:17:47] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:18:13] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:18:14] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:18:14] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:18:14] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:18:17] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:18:18] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:18:18] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:18:18] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:18:38] tagutils/tagutils-mp3.c:585: warn: File too small. Probably corrupted. [/c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3]
[2012/01/23 19:18:38] metadata.c:366: warn: Cannot extract tags from /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3!
[2012/01/23 19:18:38] scanner.c:498: warn: Unsuccessful getting details for /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3!
[2012/01/23 19:31:17] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:37:10] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:52:04] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:52:05] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:52:05] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:52:05] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:52:13] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:52:13] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:52:13] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:52:13] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:52:13] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:52:13] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:52:13] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:52:13] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 19:52:17] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:52:18] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:52:18] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:52:18] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:52:18] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:52:18] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 19:52:18] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:52:18] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:52:21] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:52:22] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:52:22] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:52:22] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:52:22] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:52:22] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:52:22] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:52:22] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 19:53:41] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:54:12] upnphttp.c:1808: error: Error opening /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3
[2012/01/23 19:54:25] upnphttp.c:1808: error: Error opening /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 02 - Shoot To Thrill.mp3
[2012/01/23 19:54:55] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:54:58] upnphttp.c:1808: error: Error opening /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3
[2012/01/23 19:55:27] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 19:55:27] upnphttp.c:1418: error: Error accessing /c/media/Pictures/album/IMG_4285.JPG
[2012/01/23 19:55:32] upnphttp.c:956: warn: HTTP Connection closed unexpectedly
[2012/01/23 19:55:34] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4283.JPG
[2012/01/23 19:55:35] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4284.JPG
[2012/01/23 19:55:37] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4285.JPG
[2012/01/23 19:58:22] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:58:23] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:58:23] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:58:23] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:58:23] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:58:23] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 19:58:23] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:58:23] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:58:27] minidlna.c:153: warn: received signal 15, good-bye
[2012/01/23 19:58:28] minidlna.c:894: warn: Starting ReadyDLNA version 1.0.20.2.
[2012/01/23 19:58:28] minidlna.c:985: warn: HTTP listening on port 8200
[2012/01/23 19:58:28] minidlna.c:997: warn: TiVo support is enabled.
[2012/01/23 19:58:28] inotify.c:89: error: inotify_add_watch(/c/media/Music) [No such file or directory]
[2012/01/23 19:58:28] inotify.c:89: error: inotify_add_watch(/c/media/Videos) [No such file or directory]
[2012/01/23 19:58:28] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC) [No such file or directory]
[2012/01/23 19:58:28] inotify.c:89: error: inotify_add_watch(/c/media/Music/AC-DC/1980 - Back In Black) [No such file or directory]
[2012/01/23 20:00:50] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 20:01:05] upnphttp.c:1808: error: Error opening /c/media/Music/AC-DC/1980 - Back In Black/AC-DC - Back In Black - 01 - Hells Bells.mp3
[2012/01/23 20:01:31] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 20:01:32] upnphttp.c:1418: error: Error accessing /c/media/Pictures/album/IMG_4285.JPG
[2012/01/23 20:01:37] upnphttp.c:956: warn: HTTP Connection closed unexpectedly
[2012/01/23 20:01:38] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4283.JPG
[2012/01/23 20:01:40] upnphttp.c:1808: error: Error opening /c/media/Pictures/album/IMG_4284.JPG
[2012/01/23 20:01:46] upnphttp.c:1418: error: Error accessing /c/media/Pictures/album/IMG_4285.JPG
[2012/01/23 20:01:51] upnphttp.c:956: warn: HTTP Connection closed unexpectedly
[2012/01/23 20:01:56] upnpsoap.c:1546: warn: Returning UPnPError 701: No such object error
[2012/01/23 20:01:59] upnphttp.c:1808: error: Error opening /c/media/Videos/movie.avi
[2012/01/23 20:02:22] upnphttp.c:1808: error: Error opening /c/media/Videos/movie.avi
