njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location ...
ripface
Feb 12, 2012Aspirant
Hi Mohare,
If any of the add-ons has "x86" at the end then they are only compatible with intel based devices. You want the EnableRootSSH that is for the ARM processor used by the ReadyNAS. You can find it here ...
http://www.readynas.com.nyud.net/downlo ... .0-arm.bin
Have fun!
Cheers,
Ripface.
Have fun!
Cheers,
Ripface.
