njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location ...
mdgm-ntgr
Mar 03, 2012NETGEAR Employee Retired
Try updating to ReadyDLNA 1.0.24: http://www.readynas.com/forum/viewtopic.php?f=76&t=27946
To install on the Dashboard, click Configure, go to the Add-ons tab, click the + button at the far right, browse for the location where you downloaded the add-on, upload the add-on etc.
After updating to 1.0.24 if that doesn't fix it this add-on will remove the ReadyDLNA database and thus force the ReadyDLNA database to be rebuilt on the new version: http://rnasguide.com/wp-content/addons/arm/DLNAREBUILDDB_0.1-arm.bin
