njfpoole
Dec 10, 2011Aspirant
ReadyDLNA rescan in NV+ V2
I've just updated from a ReadyNAS Duo to a NV+ V2. Viewing my files via DLNA is showing all sorts of 'incorrect results'. To be more specific many null folder listings and files in the wrong location ...
przemek_ch
Mar 04, 2012Aspirant
Thx,
DLNAREBUILDDB_0.1-arm.bin helped ;)
But is't just a workaround.
1. Please Add this functionality to the GUI as add on or directly to the firmware in the ReadyDLNS service section as a button.
or
2. Please fix that issue :) renaming/removing folders or files should update DLNS DB.
or
