droz1
Dec 19, 2010Aspirant
ReadyDLNA stuck scanning files have debug installed
Hey everyone, Have an odd problem that started up the other day. My ReadyDLNA service is stuck scanning files, I've restarted it several time, even turned the service off for a whole day a...
mks1
I encountered a similar issue[1] (which I posted before noticing there was a separate ReadyDLNA sub-folder) where scanning appeared to be "stuck", but in fact was no longer running due to MiniDLNA crashing. You should be able to identify the culprit(s) by logging in and manually performing the scan. Install the SSH add-on, login as root and run:
minidlna -d -R
[1]: http://www.readynas.com/forum/viewtopic.php?f=22&t=48705
minidlna -d -R
