droz1
Dec 19, 2010Aspirant
ReadyDLNA stuck scanning files have debug installed
Hey everyone, Have an odd problem that started up the other day. My ReadyDLNA service is stuck scanning files, I've restarted it several time, even turned the service off for a whole day a...
mks1
Dec 21, 2010Aspirant
I'm not sure which line in the config is causing the 'unknown option' message offhand, but you'll need to stop the ReadyDLNA service before running it manually. You can either use Frontview or the following command:
kill `cat /var/run/minidlna.pid`
