droz1
Dec 19, 2010Aspirant
ReadyDLNA stuck scanning files have debug installed
Hey everyone, Have an odd problem that started up the other day. My ReadyDLNA service is stuck scanning files, I've restarted it several time, even turned the service off for a whole day a...
droz1
May 17, 2011Aspirant
The final solution was noted in the post. You have to run DLNA in debug mode from the command line. It will tell you EXACTLY which files it has a problem with. Then you just delete them and that's it
