droz1
Dec 19, 2010Aspirant
ReadyDLNA stuck scanning files have debug installed
Hey everyone, Have an odd problem that started up the other day. My ReadyDLNA service is stuck scanning files, I've restarted it several time, even turned the service off for a whole day a...
sdouek
May 31, 2011Guide
I highly recommend that if you are not familiar with using ssh stay away from it and try to install the new addon I posted above if that still does not work then try ssh.
ssh will not show up as a addon in the addon pages.
To ssh into you box you need a ssh program most use putty. Google putty it is easy to download.
After you install it and run it fill out the appropriate information:
Host name: loacl ip address of nas ( you can use the external ip but that involves setting up your router to port forward and if you are not managing a farm of nas or clients the local will do, it also opens up a host of security issues.
port: 22
connection type: ssh
Your user id will be: root
Your password will be: what ever your admin password is at the current time you installed ssh.
Good luck be careful on what you type, it is also case sensitive too.
port: 22
