droz1
Dec 19, 2010Aspirant
ReadyDLNA stuck scanning files have debug installed
Hey everyone, Have an odd problem that started up the other day. My ReadyDLNA service is stuck scanning files, I've restarted it several time, even turned the service off for a whole day a...
sdouek
Jun 01, 2011Guide
The files might have gotten corrupt.
Have you been experiencing any re-allocated sector smart errors or even though the nas file system is enhanced not to fragment overtime your nas does becomes so fragmented from constant writes, re-writes etc. that you have to defrag the nas. I don't think the sparc base systems have that capability via frontview but I remember someone posting about it here on the forum on how to do it from the command line via ssh. I think it went something like this:
tune2fs -O dir_index /dev/c/c
umount /dev/c/c
fsck -Df /dev/c/c
*** if fsck command gives you warning mount /dev/c/c then umount it then try fsck ***
Do a search for how to defrag your nas drive, that may help you. I highly recommend before you start doing this to make a full backup of your nas and verify the backup.
umount /dev/c/c
fsck -Df /dev/c/c
