droz1
Dec 19, 2010Aspirant
ReadyDLNA stuck scanning files have debug installed
Hey everyone,
Have an odd problem that started up the other day.
My ReadyDLNA service is stuck scanning files, I've restarted it several time, even turned the service off for a whole day and turned it back on, same problem. Because it's stuck rescanning, I can only see about half of my video files on my PS3, it's the only device I use to stream. I saw a few posts that hints at certain types/kinds of files being the culprit. So I moved a few newer files off my NVX and I haven't seen change in anything. Access my video files via SMB/CIFS is fine.
I read on the forums a bit and installed the debug add-on. I poked around in the upnp-av.log file and didn't see anything obvious that stood out that would cause the problem.
Any help is appreciated
Thanks
Thanks
- mdgm-ntgrNETGEAR Employee RetiredYou can download the logs (Status > Logs > Download all logs) to get upnp-av.log if you don't want to use SSH.
