sdouek
Nov 28, 2012Guide
readydlna v4.2.22 & v1.0.25 scan in progress stuck
Readynas pro 6 business (configuration details in my signature) readydlna v4.2.22 & v1.0.25 scan in progress stuck (in frontview the scan in progress button stays greyed out) Commands typed in, ...
mrbellow
Dec 17, 2012Aspirant
Thanx sdouek for your tutorial.
Anyway probably the thing is more complex.
I had the same issue on a Ultra 2 Plus and followed your instructions step by step (I'm sure I've followed them correctly).
The problem remains after two re-installs of 4.2.21 (in frontview the scan in progress button stays greyed out).
Moreover the scanning is incomplete: I can only see a part of my music files (even after repeated scans the files I can see from my network with various dnla/upnp clients are always the same: a small part). This probably means that the dlna/upnp scan process stops when the process meets an indigestible file (even with 4.2.21).
This is a serious bug.
The use of a nas , infact, is stricly connected with the dnla/upnp function.
Hope the next release will works better with dnla
