sdouek
Nov 28, 2012Guide
readydlna v4.2.22 & v1.0.25 scan in progress stuck
Readynas pro 6 business (configuration details in my signature) readydlna v4.2.22 & v1.0.25 scan in progress stuck (in frontview the scan in progress button stays greyed out) Commands typed in, ...
sdouek
Dec 25, 2012Guide
1) In frontview go to "Streaming Services" and uncheck the following:
******* a) Automatically update database.
******* b) ReadyDLNA, enables playback of videos, music and pictures from DLNA/UPnP AV network media players.
2) Make sure both boxes are empty and then hit apply. (I initially did not do this and this is why my first downgrade did not work)
If you can't uncheck both boxes it won't work.
I would reboot unit and double check if DLNA is still offline and then proceed with the rest of the tutorial.
Make sure you are downgrading to the proper OS for your unit too.
