sdouek
Nov 28, 2012Guide
readydlna v4.2.22 & v1.0.25 scan in progress stuck
Readynas pro 6 business (configuration details in my signature) readydlna v4.2.22 & v1.0.25 scan in progress stuck (in frontview the scan in progress button stays greyed out) Commands typed in, ...
Dec 31, 2012Guru - Experienced User
Are you certain this is about file size and not something else (for instance header compression in the MKVs)? Also m2ts files break in the current readydlna
You can try installing the debug module here: viewtopic.php?f=76&t=27946
The log will then give you more information on where the scan broke.
Reinstalling the debug module reverses the logging behavior.
There are known issues with mts, m2ts in the current release. Downgrading to the older dlna might work.
Sparc: http://www.readynas.com/download/addons ... 0.24.3.bin
X86: http://www.readynas.com/download/addons ... .3-x86.bin
V2: http://www.readynas.com/download/addons ... .3-arm.bin
