darkroom081
Aug 03, 2011Aspirant
ReadyNAS 1000s - RAID Offline after disk swap
Earlier swap out of the first disk worked, but after swapping out the second one the X-RAID is offline. The system did have all HDS725050KLA360 drives, the drives being swapped in one at a time are fr...
ReadySECURE
Aug 10, 2011Apprentice
Hello,
If you have a backup (as the ReadyNAS is a storage system not a backup) you can factory default and rebuild the volume with your backup. If not you will most likely have to contact support. You say swap, do you mean you were upgrading your hard drives?
Support Resources -
Forums:
Prosafe: http://forum1.netgear.com
ReadyNAS: http://www.readynas.com/forum
Prosecure: http://prosecure.netgear.com/community/forum.php
Contact support or register a device
1-888-NETGEAR (638 - 4327) Option 4 for technical support
http://my.netgear.com
Knowledge base
http://support.netgear.com
Support Resources -
Forums:
Knowledge base
