darkroom081
Aug 03, 2011Aspirant
ReadyNAS 1000s - RAID Offline after disk swap
Earlier swap out of the first disk worked, but after swapping out the second one the X-RAID is offline. The system did have all HDS725050KLA360 drives, the drives being swapped in one at a time are fr...
darkroom081
Aug 10, 2011Aspirant
The swapping was h/d upgrading one at a time.
I have recently replaced a fan, so the system was cleaned out then. Unfortunately I don't have a backup, since this NAS is mostly used for Torrents and temporary files before there moved to one of the main NASes. I'll check to see what can be done with supports help.
