tampajim
Aug 10, 2012Aspirant
ReadyNas 1000S Disk 1 and Disk 3 Lights - Won't Boot
Ive had the ReadyNas 1100 for a number of years now. Only ever intialized it once. The ReadyNas was almost at capacity, so recently I purchased a separate storage appliance and began the process of mo...
mdgm-ntgr
Aug 10, 2012NETGEAR Employee Retired
Ah that explains it. Your light pattern is mentioned in the 1000S FAQ.
What version of RAIDiator did you install before the factory default?
On some old systems users have had trouble doing a factory default on firmware newer than 4.1.4.
I'm not sure about the flash in the 1000s. Is it replaceable? If so you could try removing the flash and rawriting the firmware to it. If that doesn't resolve the problem search the forum for the 4.1.4 archive link and try that. If that works after the resync has completed update to 4.1.8
