tampajim
Aug 10, 2012Aspirant
ReadyNas 1000S Disk 1 and Disk 3 Lights - Won't Boot
Ive had the ReadyNas 1100 for a number of years now. Only ever intialized it once. The ReadyNas was almost at capacity, so recently I purchased a separate storage appliance and began the process of mo...
mdgm-ntgr
Aug 13, 2012NETGEAR Employee Retired
Sounds like that disk may be bad. I'd suggest you hook it up to your PC and check it using the manufacturer's diagnostics e.g. SeaTools for SeaGate disks
