bigmic
Jan 22, 2011Aspirant
ReadyNAS 1000S Flash destroyed after Factory Reset [SOLVED]
Dear Forum, i am trying for hours to revive my ReadyNAS 1000S System. What happened: I was on 4.00c1-p2 and decided to upgrade to 4.1.6 - Everything went smooth. After that i upgraded to 4.1.7...
bigmic
Jan 23, 2011Aspirant
Spending another night hours i fixed it:
1) use the normal 4.1.7 firmware image (no recovery, USB or anything else) e.g. RAIDiator-4.1.7
2) get up-to-date Rawrite here http://www.netbsd.org/~martin/rawrite32/
3) rewrite the compact-flash with this image
4) press the reset-button for 30s after power on (release after the 2nd blink of all LEDs)
5) have a lot of patience
6) Problem solved
Remark: For impatient people (like me) a serial console attached to the COM1 Port inside the ReadyNAS 1000s helps a lot for knowing whats going on
Thanks to all who helped !
Thank you mdgm
6) Problem solved
Thank you mdgm
