bigmic
Jan 22, 2011Aspirant
ReadyNAS 1000S Flash destroyed after Factory Reset [SOLVED]
Dear Forum, i am trying for hours to revive my ReadyNAS 1000S System. What happened: I was on 4.00c1-p2 and decided to upgrade to 4.1.6 - Everything went smooth. After that i upgraded to 4.1.7...
PapaBear1
Feb 03, 2011Apprentice
No, you have similar symptoms. The 1000S used an actual Compact Flash drive which was removable to store the flash memory. The NV+ has a flash chip on the motherboard. Although both also use the same edition of Frontview, I believe the way of getting it on there is different if the online upgrade does not work.
