ChristianvD
May 30, 2017Aspirant
ReadyNAS 102 – Blue light blinking, no boot
Hi, My NAS has been working fine untill some weeks ago. The system does not boot anymore, the powerlight keeps flashing and i hear the disk rattling but no access via Raidar. The system is visibl...
ChristianvD
Hi StephenB,
Thanks for the advice. I've installed lifeguard but only have a laptop, so no idea how to connect the drive to the laptop.
Tried to startup the NAS with only disk 2 in it.. same issue as with Disk 1. Power button keeps blinking..
May 30, 2017Guru - Experienced User
You'll need a usb enclosure or USB->SATA adapter. Something like this: https://www.amazon.com/Sabrent-USB-DSC9-SATA-Drive-Converter/dp/B00DQJME7Y
What status is RAIDar giving you with drive 2? Also have you tried it with no disks? https://kb.netgear.com/20684/ReadyNAS-Downloads#raidar
You might need to contact Netgear. Data recovery is expensive (no matter how you do it), but it's sounding like that might be your only option. https://kb.netgear.com/69/ReadyNAS-Data-Recovery-Diagnostics-Scope-of-Service
- ChristianvDMay 31, 2017Aspirant
This is a nightmare.. bought a USB to SATA cable and try to connect to Ubuntu.. mounting does not seem to work and i have no idea what I am doing.. sudo -1...etc..
All my data is on the disk and i just want to be able to access it..
this is the second time already the netgear 102 failed me without me having anything to do with it... the firmware upgrade just failed. Thought my data would be backuped safely with this NAS..Incredible bad product & system
- StephenBMay 31, 2017Guru - Experienced User
Did you try this: https://community.netgear.com/t5/ReadyNAS-in-Business/OS6-Data-Recovery-How-to-Mount-BTRFS-Volumes/m-p/895559/highlight/true#M2167
- ChristianvDJun 01, 2017Aspirant
yes, i tried, nut nothing happens..
