sulka79
Sep 07, 2024Aspirant
ReadyNAS 102 - power and backup blinking fast
Hi, I have a problem with my ReadyNAS 102. I've been using it for several years without issues, recently I noticed I don't see it over the network, the power and backup lights are continuosly bli...
- Sep 07, 2024
sulka79 wrote:
OK, removed disks and powered on again, RAIDar still doesn't find it.
Are you seeing an IP address for it in your router's attached device list?
- If you are, can you ping it?
- If you aren't seeing it, then the chassis has likely failed.
sulka79 wrote:
I have a lot of family photos there and don't want to lose them.
One option is to connect one of the disks to a Windows PC (either with SATA or USB adapter/dock) , and see if ReclaiMe see the files.
If it does, you can get one of the two Ultimate licenses (either 7-day or not time-lmited) and then copy the files you want to other storage.
sulka79
Thanks for your answer!
That was actually the intention of having NAS, to store and protect files from losing them by keeping the data in two mirrored disks. The best would be to have it in two separate locations, also geographically, but I didn't go that far unfortunately...
I did use RAIDar but it doesn't find the file server.
I will try to connect both disks with the computer and diagnose with the tools you mentioned, but I need to get the USB adapter first.
Sep 07, 2024Guru - Experienced User
RAID is useful, but unfortunately not enough to protect your data.
That said, I do hope we can get it back.
Try removing both disks and powering up the NAS. Then see if it finds the NAS and reports a diskless status.
