vividpath
Feb 22, 2015Aspirant
ReadyNAS 102 - Remains in offline mode
Following is what I was doing on the device, when it went offline: 1) I was copying huge data(of the order of 20 GB) over the WLAN onto my ReadyNAS device, the device suddenly was not available on th...
Apr 04, 2015Guru - Experienced User
I believe support or a netgear poster here are likely to help you. You can contact support via support.netgear.com. They might want to charge, make it clear to them that you have the uninstall problem with 6.2.2.
Deno666 wrote: Hi
I am having the same problems and any knowledge to fix the issue would be appreciated
RN102 updated to 6.2.2. uninstalled camera server app now will not allow admin page to open
data is backed up, tried OS reinstall via boot menu worried factory reset will render it inaccessible.
Regards
Denis
Assuming that you don't want to wait, and that you don't have ssh enabled... -
A factory reset will fix it, but will require you to reinstall everything (and reload the data from backup).
Another option is to remove the two disks (labeling by slot) and install a scratch disk. Then upgrade the firmware to 6.2.3 beta (links are in this forum). Shut down the NAS, re-install the original disks, and power up. The NAS will automatically install the 6.2.3 beta firmware onto the original disks, which will fix the problem.
