AntonG
Nov 09, 2015Aspirant
ReadyNAS 102 6.4.0 USB_HDD Trouble: External storage device disconnected.
It seems that after upgrading firmware from 6.2 to 6.4 my USB HDD connected to rear USB port keeps disconnecting making it impossible to have unattended rsync backups or directory browsing as it used...
- Nov 15, 2015
I think the USB fixes showed up in 6.4.1-T35, not -T29.
Have you tried the current beta software?
Scads
Anton,
I had very much the same experience with my RB102 with FW 6.4.0. Since then it has been a long and disappointing process, trying to get things going again. Different firmware beta versions have made small improvements, but now there is a better one.
My advice. Disconnect UHB storage, reboot the NAS on its own. It will probably work. Update to the latest firmware 6.4.0 T147.arm.img, available elsewhere on this discussion group.
Good luck, and I hope your NAS works as mine now does.
- AntonGNov 12, 2015Aspirant
Thanks for your answer. I'm trying the suggested firmware as I write this, waiting for the nas to reboot. I hope the update will solve this issue but I'm really disappointed about what happened. The new good features do not compensate the bad ones.
Anton Giulio
- AntonGNov 15, 2015Aspirant
Hi, nothing has changed with the suggested firmware. I'm wondering if this issue has something to do with new power management policies or with a bug.
What may I look for? Disconnection seems random. I regret the update, the nas was working flawlessly with the old firmware.
Anton Giulio
- StephenBNov 15, 2015Guru - Experienced User
... trying now. Tomorrow we'll see if it works.
I'll let you know.
Meanwhile I really have to thank you so much, you are such a kind person and I'm grateful for your help.
Anton Giulio
