frankthetank
Aug 10, 2013Aspirant
ReadyNas 102 Backup Set-up problems
Hi all, I am a new owner of a readynas 102, I am quite computer/network literate however I am stumped at trying to create a backup from my PC G drive to the NAS. Whatever I enter into the source - ...
frankthetank
Aug 11, 2013Aspirant
Thanks Steve yes I have set-up a share, I am slightly confused what do I need to put in as host & path is the host my ip address of the PC then the path /g/music for example or is the host my computer name ? When I try testing the connection I always get Failed connecting to folder ?
Also is the login & password the login & password that I use to login to my pc or is this optional on the folder/share ?
Thanks for you Help
Thanks for you Help
