dagmarian
Apr 16, 2016Guide
ReadyNAS 102 compatible 2.5 inch drives
Can anyone point me to a list of 2.5 inch SATA drives that are compatible with the ReadyNAS 102? The only hardware list I can find doesn't distinguish between 2.5 and 3.5 inch drives ands I have a f...
JennC
Apr 16, 2016NETGEAR Employee Retired
Hello dagmarian,
The only list we follow is the official HCL. Others users have tried disks that are not listed but NETGEAR does not guarantee it.
See page 117 at http://www.downloads.netgear.com/files/GDC/READYNAS-100/RN_OS_6_Desktop_HW_UM_12Oct2015.pdf for steps how to add 2.5in HDD/SSD.
- dagmarianApr 16, 2016Guide
JennC thanks for your quick reply - however I'm still not wiser about determining which, if any, of the drives listed on the HCL are 2.5 inch ones. Am I missing something?
- mdgm-ntgrApr 16, 2016NETGEAR Employee Retired
Most drives are 3.5 inch.
Why do you particularly want to use a 2.5" disk?- dagmarianApr 17, 2016Guide
Hi, I'm thinking of buying an OWC device like this and was attracted by the possibility of using the same drive subsequently in the ReadyNAS if my setup and needs evolved.
