dagmarian
Apr 16, 2016Guide
ReadyNAS 102 compatible 2.5 inch drives
Can anyone point me to a list of 2.5 inch SATA drives that are compatible with the ReadyNAS 102? The only hardware list I can find doesn't distinguish between 2.5 and 3.5 inch drives ands I have a f...
dagmarian
Apr 16, 2016Guide
JennC thanks for your quick reply - however I'm still not wiser about determining which, if any, of the drives listed on the HCL are 2.5 inch ones. Am I missing something?
mdgm-ntgr
Apr 16, 2016NETGEAR Employee Retired
Most drives are 3.5 inch.
Why do you particularly want to use a 2.5" disk?
- dagmarianApr 17, 2016Guide
Hi, I'm thinking of buying an OWC device like this and was attracted by the possibility of using the same drive subsequently in the ReadyNAS if my setup and needs evolved.
- StephenBApr 17, 2016Guru - Experienced User
2.5" support is mainly for SSDs. There are a handful of SSDs on the HCL, most are very old models.
I think using your hand-me-down drives in your NAS is not a good idea. You are better off getting drives that are intended for NAS. WDC Red, Seagate VN are both affordable and have better warranties than desktop drives.
Yep, sounds like good advice. I already have a WD Red
drive in the ReadyNAS (just one at present whilst I figure out what it's good for and what it's not - such as Time Machine backups over WiFi!
I just like to be able to explore the claimed functionality and for documentation and info from suppliers / manufacturers to be coherent.
regards,
