jnureno
Feb 11, 2016Aspirant
[ReadyNAS 102] Device Communication Error
Hello. I am fairly new to NAS systems and recently purchased a ReadyNAS 102 2 bay to give my workplace more harddrive space, and to add RAID support. For 8 months now, everything has been going great...
mdgm-ntgr
Feb 11, 2016NETGEAR Employee Retired
Which firmware is on the two units?
Have you checked that both units can connect to the internet i.e. email alerts work from both units?
Welcome to the Community!
- jnurenoFeb 12, 2016Aspirant
Hi, and thanks!
The 1st box has firmware 6.4.2, and the 2nd box can't make it past the discovery step.
This is what I see when I hit Discover: http://i.imgur.com/xiXHIwS.pngThis is the next thing I see when I hit Setup: http://i.imgur.com/PVAaL6f.png
This is the error I get when I try and http://i.imgur.com/0eOzHfg.png
So I can't even get to the admin area where I can setup email alerts, update firmware, etc...
Hope this helps some.
- mdgm-ntgrFeb 12, 2016NETGEAR Employee Retired
Can you try offline setup of the new box, update the firmware on the new box, verify the update is successful, then do a factory default (wipes all data, settings, everything) and try ReadyCLOUD setup again?
- jnurenoFeb 15, 2016Aspirant
Sorry for the late reply, I am back to work now.
I will have to read up on how to setup offline this morning. I wasn't sure which numbers to plug in on that screen.
I will let you know soon if it works, thanks!
P.S. This is a brand new box + HDD.
EDIT: The offline mode is working. I am updating firmware now. Will keep you updated on the next steps.
