djambalawa
Sep 01, 2014Aspirant
readynas 102 ethernet port dead
Hi I think my readynas is still under warranty but how can I get the data of my readynas before I send it in or whatever? The Ethernet port is dead for some reason - no lights on the switch. Sam...
Sep 01, 2014Guru - Experienced User
I'm sure support will give you instructions, just do what they tell you.
xeltros wrote: I forgot to say that you shouldn't send the disks with the NAS, but this was implied in my answer.
You will keep the disks, I'm not sure how they handle the trays. The replacement should be compatible (most likely identical). If for some reason its not identical, post a followup here before you insert the disks.
