dvsu12
Oct 12, 2015Tutor
Readynas 102 frozen after attempted firmware upgrade from v6.1.6 to v6.4.0
Hi all, Attempted to updated my Readynas 102 last night from firmware version 6.1.6 to version 6.4.0. The unit downloaded the update, but when it asked to reboot, it had lost connection with ...
- Oct 13, 2015Cheers.
USB recovery back to the original 6.1.6 firmware got it working 100% again.
dvsu12
Oct 12, 2015Tutor
Will be attempting the USB recovery method outlined above - will attempt to restore the v6.1.6 firmware.
HWStigter
Oct 12, 2015Apprentice
For my RN104 (originally running 6.3.5) I've done the USB recovery (cf. the instructions above) and have reinstalled the OS (the 'reset button procedure' to acces the boot menu cf. http://kb.netgear.com/app/answers/detail/a_id/22891) but no improvement. I'm currently in 'Read-Only boot-mode"(same URL) and backing up whatever I normally don't backup so that I can do a 'factory default' afterwards (also explained on the same URL).
I will need at least 12 hours to copy off the remaining data, so I won't be able to tell you what my results are until tomorrrow, but I will update this information ASAP.
