tthumb's avatar
tthumb
ReadyNAS 102 Power Led 2 flashes pause repeat endlessly
I had a 2 TB disk. I am good with a single disk. I added a 5TB. It synced and was ready after a few hours. I pulled out the 2TB disk from the first bay. Confirmed I could access data and Admin UI. Moved the 5TB to bay 1 with the second bay empty.
After 24 hours -
1. system only shows 2 TB available (though the disk shows as 5 TB)
2. Power light is blinking in a specific pattern; 2 quick flashes; a 2 sec pause. Repeating endlessly.
Bottom line: I want it to see and access the full 5TB.  What do I need to do?
Any help will be truly appreciated.
    Start over.  The procedure you followed gave you a 2 TB RAID-1 volume (since RAID-1 is mirrored, the volume is the size of the smaller disk).  Then removing the 2 TB drive gave you a degraded RAID-1 volume.
    What you should have done is switched to flexraid, inserted the new disk, and created a new JBOD volume.  Then create new shares on the new disk, and copy the data over (backup jobs are convenient).  Finally, destroy the old volume, remove the old disk, and rename the new shares to match the original.
    Getting there from where you are is a bit tricky.  If you can connect the old disk to a PC, you might find it easier to simply copy off all the files from the NAS to the PC, and then do a factory default and set it up again.
  • StephenB's avatar
    • tthumb's avatar
      tthumb
      Thank you for the quick response. Very helpful.
      Will it be faster if I do a backup of the drive as it stands now, then do a factory reset, start with the 5 GB reformat and then try to do a restore?
      I could do a Flex Raid in the process, too.
      So, basically, will a backup and restore work?
      • tthumb's avatar
        tthumb
        Actually, never mind.  I had not realized how backups (and backup jobs) work. That is exactly what you said. I just happened to have a spare 2 TB sitting around that I put in a USB enclosure and got it going as a local (external) backup of the data.
        Again, thank you for your quick response. All good.
ProSupport for Business
