Mark_T_H
Nov 14, 2018Tutor
ReadyNAS 102 Power LED flashing after power failure
Our ReadyNAS has a single factory supplied drive in bay 1. We had a power failure that has left the ReadyNAS 102 with a flashing power LED.
Initially the unit would not shut down pressing the power button twice, so I had to pull the power plug, press the reset button, and plug the power cord in. I was able to select OS reinstall and the release the reset button. Nothing changed over night, the power LED was still flashing the next morning.
So I tried the two pushes on the power button and nothing happened, still flashing power LED. When I tried the pulling the power plug, pressed reset button, plugged in the power cord, then started the scroll through boot modes, all the lights went out except the power LED and the Act light. No other options scrolled by. When I released the reset button, the disk one light came on and the power LED started flashing again.
I cannot log into the device with a web browser, and when I look at the ReadyCloud page I only see some of the document folders...
-Mark
You might try RAIDar 6.4, and let us know what status it sees for the NAS. https://kb.netgear.com/20684/ReadyNAS-Downloads
- Mark_T_HTutor
RAIDar 6.4 says;
Status: Previously formatted disk(s) detected (Dirty Disks)
Firmware: 6.9.2
"The disks installed on this ReadyNAS system are formatted in a file system that the system does not recognize. You must reformat these disks in a recognized file system to continue set-up. reformatting disks means that you will lose any data on them. Click Format to continue."
Wow! That's what happens after a power failure!! I can't get the device to respond in any way, but RAIDar will reformat the disks anyway? There has to be another option to retrieve the data off this device. Is the Data still in ReadyCloud?
-Mark
ReadyCloud is a VPN that provides access, it doesn't include cloud storage.
What you could try is getting the Paragon Linux-for-Windows package (~$20): https://www.paragon-software.com/us/home/linuxfs-windows/ That does support btrfs - if the file system isn't corrupted it should be able to access the data volume if you connect one of the RN102 disks via USB. Though I haven't tested this with RAID-1 myself.
ReclaiMe RAID recovery software is another option, though much more expensive.
You could also try paid Netgear support (my.netgear.com).
Bad things can happen when cached writes are lost. I always recommend using a UPS with all NAS. FWIW you should also have a backup plan in place, since RAID alone isn't enough to keep data safe.
