EFrankWade
Feb 29, 2016Aspirant
ReadyNAS 102 Source will not MOUNT
Win 7 PC - Norton Internet is off. The source director can be accessed from two (2) other PC. One Windows Home Server and another Win 7. Alll on same 1 GB network (WadeGroup) I have spent...
- Mar 03, 2016
Stephen,
Thank you for your suggestions on my issue. I was able with your help, and a little luck, to get the ReadyNAS to WORK. The final solution was to use the source IP in the Host field instead of the computer name. Another interesting item is that the windows DNC back slash "\" is automaticly changed to Unix foward slash "/" when I selected the start button. Keep up the good work.
Frank
Feb 29, 2016Guru - Experienced User
These are likely things you've already tried, but just in case ...
(1) check the account credentials used in the backup job to access the share
(2) check the "share with" for the documents library.
(3) Ensure the workgroups match
