MarkJPearce
Jun 16, 2017Aspirant
ReadyNas 104 - Network overrun errors
Hi, I have a ReadyNAS 104 running at firmware v 6.7.4 and I have recently started noticing the following errors when running journalctl: Jun 16 13:59:39 GlassNib-NAS kernel: mvneta d0074000.e...
Jun 16, 2017Guru - Experienced User
Overall, an rx overrun in the NAS means that the NAS itself isn't able to keep up with the data it is receiving.
Try turning on ethernet flow control in your PCs (both tx and rx). If you have managed or smart switches, look for flow control settings in them also.
These shouldn't do damage, as TCP will retransmit.
