Richard-P
Mar 29, 2021Aspirant
Readynas 104 - Very slow, almost unusable
Hi, I'm using a readynas 104 with 6.10.4 Hotfix 1 OS. It's extremely slow, almost unusable and I can't get any work done, which is a real problem. The latest log says 'System: ReadyNASOS backgroun...
Mar 29, 2021Guru - Experienced User
Richard-P wrote:I'm using a readynas 104 with 6.10.4 Hotfix 1 OS.
Start by downloading the full log zip file from the log page. Then look in disk-info.log and see if there are disk errors in the smart stat counts.
Also, did the speed drop recently? Or has it been slow for a while?
Did you try simply rebooting the NAS?
- Richard-PMar 29, 2021Aspirant
Hi Stephen,
Thanks for replying so quickly.
There doesn't appear to be any disk errors.
The speed issue started on Friday . Until then there hasn't been any issues with it.
I've tried re-booting the nas a coule of times but it doesn't help, unfortunately.
Thanks,
R
- rn_enthusiastMar 29, 2021Virtuoso
Hi Richard-P
Take that log zip file you downloaded and upload that to Google drive, Dropbox or similar. Then PM me a link to download it and I can take a look for you, in those logs. Might be able to see what is going on.
Cheers
That's really good of you, thanks.
