smst
Jul 18, 2023Aspirant
ReadyNAS 104 [6.10.8] - Python 2.7 has disappeared
Hi all, I have a ReadyNAS 104. Last night I checked the dashboard and saw that firmware 6.10.8 was available to install, so I installed it. One of my apps stopped working, and some command-line in...
smst
Jul 19, 2023Aspirant
I have a lot more than that, even in /usr/lib, which makes me think I have in fact installed some extras at some point. Since I'm not using the NAS as a print server anyway, I wonder if I should just force the apt-get to update everything then -- it doesn't matter to me if cups breaks, as long as it isn't going to matter to some app that thinks it needs cups to work.
Thanks for the reply -- would you be able to check what you have in terms of /usr/bin/python* please?
Jul 19, 2023Guru - Experienced User
root@NAS:~# ls -als /usr/bin/python*
4 lrwxrwxrwx 1 root root 9 Mar 16 2015 /usr/bin/python -> python2.7
4 lrwxrwxrwx 1 root root 9 Mar 16 2015 /usr/bin/python2 -> python2.7
root@NAS:~## ls /usr/lib/python2.7
_abcoll.pyc dircache.pyc _LWPCookieJar.pyc pstats.py sunau.py
abc.pyc dis.pyc macpath.py pstats.pyc sunau.pyc
aifc.py dist-packages macpath.pyc pty.py symbol.py
aifc.pyc distutils macurl2path.py pty.pyc symbol.pyc
antigravity.py doctest.py macurl2path.pyc pyclbr.py symtable.py
antigravity.pyc doctest.pyc mailbox.py pyclbr.pyc symtable.pyc
anydbm.py DocXMLRPCServer.py mailbox.pyc py_compile.pyc _sysconfigdata.pyc
anydbm.pyc DocXMLRPCServer.pyc mailcap.py pydoc_data sysconfig.pyc
argparse.egg-info dumbdbm.py mailcap.pyc pydoc.py tabnanny.py
argparse.py dumbdbm.pyc markupbase.py pydoc.pyc tabnanny.pyc
argparse.pyc dummy_threading.py markupbase.pyc _pyio.py tarfile.py
ast.py dummy_threading.pyc md5.pyc _pyio.pyc tarfile.pyc
ast.pyc dummy_thread.py mhlib.py Queue.py telnetlib.py
asynchat.py dummy_thread.pyc mhlib.pyc Queue.pyc telnetlib.pyc
asynchat.pyc email mimetools.py quopri.py tempfile.pyc
asyncore.py encodings mimetools.pyc quopri.pyc test
asyncore.pyc ensurepip mimetypes.py random.pyc textwrap.pyc
atexit.pyc filecmp.py mimetypes.pyc repr.pyc this.py
audiodev.py filecmp.pyc MimeWriter.py re.pyc this.pyc
audiodev.pyc fileinput.py MimeWriter.pyc rexec.py _threading_local.py
base64.pyc fileinput.pyc mimify.py rexec.pyc _threading_local.pyc
BaseHTTPServer.py fnmatch.pyc mimify.pyc rfc822.py threading.py
BaseHTTPServer.pyc formatter.py modulefinder.py rfc822.pyc threading.pyc
Bastion.py formatter.pyc modulefinder.pyc rlcompleter.py timeit.py
Bastion.pyc fpformat.py _MozillaCookieJar.py rlcompleter.pyc timeit.pyc
bdb.py fpformat.pyc _MozillaCookieJar.pyc robotparser.py toaiff.py
bdb.pyc fractions.py multifile.py robotparser.pyc toaiff.pyc
binhex.py fractions.pyc multifile.pyc runpy.pyc tokenize.pyc
binhex.pyc ftplib.py multiprocessing sched.py token.pyc
bisect.pyc ftplib.pyc mutex.py sched.pyc traceback.pyc
bsddb functools.pyc mutex.pyc sets.py trace.py
calendar.pyc __future__.pyc netrc.py sets.pyc trace.pyc
CGIHTTPServer.py genericpath.pyc netrc.pyc sgmllib.py tty.py
CGIHTTPServer.pyc getopt.pyc new.py sgmllib.pyc tty.pyc
cgi.py getpass.py new.pyc sha.pyc types.pyc
cgi.pyc getpass.pyc nntplib.py shelve.py unittest
cgitb.py gettext.py nntplib.pyc shelve.pyc urllib2.py
cgitb.pyc gettext.pyc ntpath.py shlex.py urllib2.pyc
chunk.py glob.pyc ntpath.pyc shlex.pyc urllib.py
chunk.pyc gzip.py nturl2path.py shutil.pyc urllib.pyc
cmd.py gzip.pyc nturl2path.pyc SimpleHTTPServer.py urlparse.py
cmd.pyc hashlib.pyc numbers.py SimpleHTTPServer.pyc urlparse.pyc
codecs.pyc heapq.pyc numbers.pyc SimpleXMLRPCServer.py UserDict.pyc
codeop.py hmac.py opcode.pyc SimpleXMLRPCServer.pyc UserList.py
codeop.pyc hmac.pyc optparse.pyc sitecustomize.pyc UserList.pyc
code.py hotshot os2emxpath.py site.pyc user.py
code.pyc htmlentitydefs.py os2emxpath.pyc smtpd.py user.pyc
collections.pyc htmlentitydefs.pyc os.pyc smtpd.pyc UserString.py
colorsys.py htmllib.py _osx_support.py smtplib.py UserString.pyc
colorsys.pyc htmllib.pyc _osx_support.pyc smtplib.pyc uuid.py
commands.py HTMLParser.py pdb.doc sndhdr.py uuid.pyc
commands.pyc HTMLParser.pyc pdb.py sndhdr.pyc uu.py
compileall.pyc httplib.py pdb.pyc socket.pyc uu.pyc
compiler httplib.pyc __phello__.foo.py SocketServer.py warnings.pyc
ConfigParser.pyc ihooks.py __phello__.foo.pyc SocketServer.pyc wave.py
contextlib.pyc ihooks.pyc pickle.pyc sqlite3 wave.pyc
cookielib.py imaplib.py pickletools.py sre_compile.pyc weakref.pyc
cookielib.pyc imaplib.pyc pickletools.pyc sre_constants.pyc _weakrefset.pyc
Cookie.py imghdr.py pipes.py sre_parse.pyc webbrowser.py
Cookie.pyc imghdr.pyc pipes.pyc sre.pyc webbrowser.pyc
copy.pyc importlib pkgutil.pyc ssl.pyc whichdb.py
copy_reg.pyc imputil.py platform.pyc stat.pyc whichdb.pyc
cProfile.py imputil.pyc plat-x86_64-linux-gnu statvfs.py wsgiref
cProfile.pyc inspect.pyc plistlib.py statvfs.pyc wsgiref.egg-info
csv.py io.pyc plistlib.pyc StringIO.pyc xdrlib.py
csv.pyc json popen2.pyc stringold.py xdrlib.pyc
ctypes keyword.pyc poplib.py stringold.pyc xml
curses lib2to3 poplib.pyc stringprep.pyc xmllib.py
dbhash.py lib-dynload posixfile.py string.pyc xmllib.pyc
dbhash.pyc lib-tk posixfile.pyc _strptime.py xmlrpclib.py
decimal.py LICENSE.txt posixpath.pyc _strptime.pyc xmlrpclib.pyc
decimal.pyc linecache.pyc pprint.py struct.pyc zipfile.py
difflib.py locale.pyc pprint.pyc subprocess.pyc zipfile.pyc
difflib.pyc logging profile.py sunaudio.py
dircache.py _LWPCookieJar.py profile.pyc sunaudio.pyc
I am running 6.10.9. Though I never explicitly installed python, I did install plex a long time ago - which does include python2.7 I might not have installed plex on one of my backup NAS - I'll check when I have a chance and I'll follow up..
- StephenBJul 19, 2023Guru - Experienced User
Definitely due to plex. My backup Pro 6 NAS doesn't have Plex installed, and just has this:
root@PRO:~# ls -als /usr/lib/python2.7 total 0 0 drwxr-xr-x 1 root root 26 Aug 27 2018 . 0 drwxr-xr-x 1 root root 1680 Jun 4 15:11 .. 0 drwxr-xr-x 1 root root 20 Jun 4 15:10 dist-packages
