mrGarret
Sep 04, 2017Aspirant
ReadyNas 104 Booting... (web gui firmware update)
Hellow everyone. After updating the firmware from web gui (6.1.8 to 6.8.0) my RN104 has "Booting ..." on the display. Attempt: OS Reinstall (with or without disks) Factory Default (with or withou...
- Sep 20, 2017
Solved.
1)Boot off USB (hold "backUP button" when power ON) with NTGR_DEBUG.txt on flash (but without FW)
2)In RAIDar_6.3.0 i saw that microcode version on my nas is 6.2.4
3)I made a recovery USB flash drive with 6.2.4 FW and (without NTGR_DEBUG.txt) and "boot off USB"
4)A few minutes later the NAS automatically shut down
5)On next boot (normal boot, but with flash drive) NAS done automatic FW restore
6)After i done FW update (with GUI) 6.2.4 >>> 6.2.5 >>> 6.5.2 >>> 6.8.0
JennC
Sep 04, 2017NETGEAR Employee Retired
Hello mrGarret,
Can you still get to the files? Can you post what RAIDar says about the NAS?
Welcome to the community!
mrGarret
No, i cant get data from device, but i have backUP =)
Before updating the firmware on the device was RAID6 on 4HDD.
Is it possible to return the device to work (data loss does not matter)?
- martinhjSep 05, 2017Luminary
I would agree, as a novice if I were to go i nto the GUI and the device tells me there is an update I would expect it to update to something that worked wihtout having to trawl through release notes to realise I must manually go and download an intermediate firmware.
Personally I update regularly and do these checks but a novice would not I am sure!
- mrGarretSep 05, 2017Aspirant
Also i have "PL2303TA USB TTL RS232" cable.
It can be possible to download the firmware via serial connection to the ReadyNAS?- SandsharkSep 05, 2017Sensei
I believe that a factory default should fix the problem. It wipes out everything, but you say you have a backup (good!). You can confirm that by putting in a spare drive and seeing if it comes up that way. If that doesn't work, a USB OS recovery should work.
