mrGarret
Sep 04, 2017Aspirant
ReadyNas 104 Booting... (web gui firmware update)
Hellow everyone. After updating the firmware from web gui (6.1.8 to 6.8.0) my RN104 has "Booting ..." on the display. Attempt: OS Reinstall (with or without disks) Factory Default (with or withou...
- Sep 20, 2017
Solved.
1)Boot off USB (hold "backUP button" when power ON) with NTGR_DEBUG.txt on flash (but without FW)
2)In RAIDar_6.3.0 i saw that microcode version on my nas is 6.2.4
3)I made a recovery USB flash drive with 6.2.4 FW and (without NTGR_DEBUG.txt) and "boot off USB"
4)A few minutes later the NAS automatically shut down
5)On next boot (normal boot, but with flash drive) NAS done automatic FW restore
6)After i done FW update (with GUI) 6.2.4 >>> 6.2.5 >>> 6.5.2 >>> 6.8.0
Sandshark
Sep 05, 2017Sensei
I believe that a factory default should fix the problem. It wipes out everything, but you say you have a backup (good!). You can confirm that by putting in a spare drive and seeing if it comes up that way. If that doesn't work, a USB OS recovery should work.
JennC
Sep 05, 2017NETGEAR Employee Retired
Hello mrGarret,
Updating from a very very old firmware must have caused the problem. Like Sandshark said, it may be best to factory reset since you have backup of the data.
